Need Help! CW8060 connection
Results 1 to 3 of 3
Thread: CW8060 connection
    Member view2's Avatar
    Apr 2019
    Default CW8060 connection
    I am new here.
    Can anyone help me to connect CW8060 driver to the breakout board?
    CP+
    CP-
    CW+
    CW-
    EN+
    EN-
    Thanks!
    Attached Thumbnails Attached Thumbnails CW8060 connection-bord1-jpg   CW8060 connection-bord2-jpg   CW8060 connection-cw8060-jpg   CW8060 connection-draw1-jpg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: CW8060 connection
    once you deside if your going to use a common +5V connection to CP+ , CW+ & EN+ or common -5V connection to CP- , CW- & EN- to the CW8060 stepper drivers
    assuming your using Mach 3 in pins and ports you will need to assign the function of the BOB output pins P4 to P9 and pins P16 & P17
    by default if you don't connect the stepper driver enable terminals (EN + EN-) the driver will be enabled
    so the minimum connections to the driver is the common +5V or 0V , clock pulse CP and Direction CW
    for a 4 axis machine you could make
    P9 the X axis CP P8 X axis CW
    P7 the Y axis CP P6 Y axis CW
    P5 the Z axis CP P4 Z axis CW
    P17 the A axis CP P16 A axis CW
    CW8060 connection-bob-driver-connections-jpg
    John
    Apr 2019
    Many thanks John!
CW8060 connection
CW8060 connection
