Need Help! Stepper motor, voltage and inductance
Results 1 to 5 of 5
Thread: Stepper motor, voltage and inductance
    Aug 2013
    Question Stepper motor, voltage and inductance
    Hello Dears,
    I have a burned-out steper motor : 86BHH76-400B-35J with technical data: Current: 4A, Inductance: 3.5 mH, Resistant: 0.62 Ohm
    Can I replace it with 85BYGH450A-06-05J - Current: 4A, Inductance: 2.3 mH, Resistant: 0.5 Ohm
    The difference are Resistant and Inductance.
    My power supply is 70V AC and stepper driver dma860h. Machine works on low feed rate.
    Feb 2008
    Default Re: Stepper motor, voltage and inductance
    Looks like it should work fine (same current/torque)
    Lower inductance so maybe a bit better high speed performance
    Lower resistance so less power dissipation
    Aug 2013
    Thanks Dear,
    are 70 Volts for the Inductance: 2.3 mH OK?
    Feb 2008
    Quote Originally Posted by smart81bg View Post
    Thanks Dear,
    It should be fine, ripple current will be higher but I'm pretty sure the
    DMA860 has a 50 KHz or so switching frequency so the ripple will be minmal
    Aug 2013
    Quote Originally Posted by PCW_MESA View Post
    Thanks I will try, Hope will no damage anyting, Yes it is 70V AC.
