adding inertia dampeners on nema34
Results 1 to 4 of 4
Thread: adding inertia dampeners on nema34
    Apr 2018
    Belgium
    Default adding inertia dampeners on nema34
    hi everyone,
    i have a plasma table with nema34 motors on it.
    these have at certain speed vibrations.
    i would like to add some inertia dampener to help that.
    here's where i got the idea from:
    https://www.cnczone.com/forums/stepp...er-damper.html
    issue is that my stepper motors only have 1 shaft.
    the back of the motor has a round detent of 30mm in diameter and about 3mm deep.
    at the bottom of this detent there is a thin plate (i can see it move when i push on it).
    here's a picture:
    https://www.cnczone.com/forums/attac...d=412332&stc=1
    does anybody know if it's possible to attach a dampener to this motor
    this is what i wanna add to the motor:
    https://www.cnczone.com/forums/attac...d=412334&stc=1
    does anyone know what there is behind the thin plate?
    could i attach the dampener to whatever there is?
    thank you
    Attached Thumbnails Attached Thumbnails adding inertia dampeners on nema34-img_20190204_151832-jpg   adding inertia dampeners on nema34-draft1-jpg
    Jun 2015
    Sweden
    Default Re: adding inertia dampeners on nema34
    Why not trying a stepper drive with mid-band resonance damping? I mean that is also a solution for your problem.
    I think the dampener will only shift the resonance band, it will not likely to fully resolve the issue.
    Apr 2018
    Belgium
    Quote Originally Posted by OlfCNC View Post
    i bought the table from a company who made the machine, but they are no longer in buissines.
    i don't have the know how to install new drivers.
    on the thread i linkend to alot of people have really great result, seems like it's worth a try.
    Jun 2011
    There may be a preload spring or something in there. Modifying the motor seems quite risky to me. I think I'd replace the motors with equivalent dual shaft motors, or upgrade the drives. There may be drop-in replacements for the drives available, stepper drives are fairly interchangeable.
