Driver settings
Results 1 to 4 of 4
Thread: Driver settings
    May 2018
    Default Driver settings
    Dear all,
    I have a DM542T driver and I am not sure about the settings to choose.
    In the settings of microstepping is not explained how to set it with full step. I think to do it I have to put all the switches in ON position... do you confirm it?
    Furthermore I am using a Nema23 that is rated at 2.8 Amps. I don't know if I have to set the driver for 2.8 Amps of peak current or of RMS current?
    Registered sprintcar72's Avatar
    Jan 2016
    Default Re: Driver settings
    I just completed a small plasma table with the same component selection as yours. Page 7 in the manual linked below should answer your questions.
    https://www.omc-stepperonline.com/download/DM542T.pdf
    Sent from my iPad using Tapatalk
    May 2018
    I had already read the manual, but both my questions are not solved there...
    Mar 2003
    The most commonly used microstep settings are 1/8 or 1/10.
    Use the peak current.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
Driver settings
Driver settings
