It depends on the pitch of your screws. If you are going to use something like 5mm pitch ballscrews, 1000 rpm would be 196 inches per minute feedrate. Way faster than is needed for a X2.
If you are going to keep the stock, i assume 0.1" pitch acme screws, 1000 rpm is 100 IPM. Still faster than you need on an X2, but you have screws that are much harder to turn than a ballscrew. Also, the torque curves at 48V show that the point where the torque curves cross is not at 1000 rpm, but more like 250 rpm. At 250 rpm and 5mm ballscrews you are about 50 ipm.
Really for an X2, 50 IPM is enough. An X2 has about 8 inches travel on the x axis and less on the other 2 axes, so at 50 IPM it would take only 8 seconds for full end to end travel. Most cutting on say aluminum is going to be 20 IPM or less on an X2
I'd personally go with the 425 on an X2 and the speed you get is what you get, but I would call John at Automation Tech and see what he can do for you about upgrading to a 48V power supply. The 7.3A 48V PS is the same price as the 9.7A 36V PS and 7.3A is plenty for those motors. He may just do a swap for you.
To answer your question about what voltage does, you can see it in the one plot you posted that shows 48V vs 80V. It basically shifts the curve to the right as you go up in voltage
