NEMA 34
Results 1 to 5 of 5
Thread: NEMA 34
    *Registered User* cncfoamshaper's Avatar
    Oct 2018
    Default NEMA 34
    Quick question for anyone with experience on nema 34 steppers....Can I run a 34 on the same driver and control board (in theory anyway) that I've been running my 23's on ?
    Dec 2013
    Default Re: NEMA 34
    Control board, no problem. If the output of your existing drive is compatible with the rated current of the NEMA 34 motors then no problem.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2018
    Default Re: NEMA 34
    thanks
    May 2015
    Default Re: NEMA 34
    Yes, I do that (use controllers originally purchased for NEMA 23's with NEMA 34's on the one machine) I did look hard at the current consumption though!
    Rod Webster
    www.vmn.com.au
    Jun 2011
    Default Re: NEMA 34
    As others mentioned, control board will be fine, but if your driver is sized for a NEMA 23, it probably will not be ideal for a NEMA 34 motor. Most are rated for higher current and have higher inductance, so need higher voltage to run well at higher RPM's.
NEMA 34
NEMA 34
