I think this is incredibly optimistic, and likely unattainable.Resolution: 0.0001in (0.0025mm)
What are the specs of the screws? Can you fabricate the machine to these tolerances? Will it be in a temperature controlled room?
I would forget about steppers, and look at AC servos in the .75-1Kw range. Much higher resolution, and a lot more power.
