That is hard to answer if you don't tell what you have. Upload some foto's, link to the board etc.does anyone have a similar board to mine?
Hi Guys,
I am totally new to this,i hooked up the driver board and the power supply everything turns on.
But nothing happens do not know if its the wires or the settings in mach3.
I have seen many videos on youtube on the TB6560AHQ board but there are some differences my board does not identify at the connections like other TB6560AHQ boards with an X or Y or Z at the green terminals for the motors they have numbers saying D12 D21 D16 so on so I am guessing which is the X Y or Z connectors, I have seen many boards on youtube similar but not exactly as mine so I do not know if my connections are correct or if my Mach3 is set up correctly for the parallel port and the pin setting does anyone have a similar board to mine?
I have Nema 23 motors with 4 color wires red blue black and green
Well here is one manual: https://www.victortrucco.com/CNC/Cor...xis_Manual.pdf but you really need to specify the boards manufacture. TB6560 is a Toshiba part number for a chip they use, the boards could otherwise be made in a variety of ways. A Toshiba document on the actual chip can be found here: TB6560AHQ | Motor Drivers | TOSHIBA Semiconductor & Storage Products | Americas. Both of these came up in a search on the net immediately. In any event the board implementation documentaiton is what you need and that comes from the manufacture.
I will try and see who manufactured this board thanks
ok thanks on the manual.pdf file will try to follow and see what happens also I don't know who manufactured this board
