if you can not download the instructions for your L298N board from the supplier
try comparing your board with the L298N dual H bridge data sheet from
https://www.st.com/en/motor-drivers/l298.html
how are you using the L298N?
normally the 4 inputs connect to the outputs of a L297N
L298N PDF data sheet
L298.pdf
see page 8 for connections to L297N
John
