Need Help! Taig stepper motor problems
Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Taig stepper motor problems
    Jul 2014
    Default Taig stepper motor problems
    Hello everyone, I been having problems with my Nema 23 steppers. They have lost their torque. All four at once. I have been working with tech support but they have not been able to figure out the problem. I am using Mach3 as the control. So far this is what I have done:I increased the velocityI increased the stepsI checked the voltage of the capacitors in the control box and double checked the fusesI checked the CPU usage I bought a new/used computer with windows xp 32 bitOne interesting point, the new/used computer ran with less torque and less power. If you can help please do!thank You
    Gold Member jalessi's Avatar
    Feb 2007
    Items for Sale
    Default Re: Taig stepper motor problems
    pbmwco,
    Copy *.xml files from the "C:\mach3" old computer to the new computer
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2014
    Hi Jeff and thank You for your reply. I did. I copied all the necessary files. I also verified that the com cable is good.
    Feb 2007
    Items for Sale
    Are you 100 percent positive you are using the xml files that worked correctly with the old computer?
    Jul 2014
    Yes, 100%
    Feb 2007
    Items for Sale
    What happens when you reattach the old computer, does the stepper performance return to normal?
  7. #7
    Jul 2014
    Yes, but still ahs the original problem of low torque.
  8. #8
    Feb 2007
    Items for Sale
    What stepper drives are you using?
  9. #9
    Jul 2014
    Nema 23
  10. #10
    Feb 2007
    Items for Sale
    What stepper drives (electronics) are you using not stepper motors?
    Please post images.
  11. #11
    Jul 2014
    I am using the controller produced by micro-proto. I have been on tech support with them but it's moving very slowly.
    Attached Thumbnails Attached Thumbnails Taig stepper motor problems-side-1-jpg   Taig stepper motor problems-inside-jpg
  12. #12
    Feb 2007
    Items for Sale
    Are you using backlash comp in Mach3, if so try disabling it.
    Attached Thumbnails Attached Thumbnails Taig stepper motor problems-bl-jpg
