Need Help! Need spec sheet for stepper motors
Results 1 to 9 of 9
Thread: Need spec sheet for stepper motors
    Mar 2006
    Default Need spec sheet for stepper motors
    I have 2 stepper motors for which I need the specification sheets for each motor.
    Motor #1 is marked with the information below:
    Type 23HD450Y-31A6
    FH 170713 Smooth (with registration mark)
    Motor #2 is marked with the information below:
    Type 57BHH56P-560A-29
    CW No. 2017.04.17
    Any help in regard to where to find the spec. sheets, how to identify the motors, the identity of or someone who can identify the motors would be appreciated.
    Thank You
    Roger
    Mar 2017
    China
    Default Re: Need spec sheet for stepper motors
    57BHH56P-560A-29
    Power: 20w,
    Voltage: 24V,
    Rated current: 1.2A
    andy@union-cnc.com
    https://www.cnczone.com/forums/attac...d=392068&stc=1
    Attached Thumbnails Attached Thumbnails Need spec sheet for stepper motors-_20180427143946-jpg
    Mar 2006
    Andy,
    Thank you for your response and the information.
    I'm assuming this stepper motor is a 4 wire bipolar motor, is that correct?
    Do you have a specification sheet for this motor or where I can obtain a specifications sheet?
    Do you know who the manufacturer is for this stepper motor?
    Do you know where I can buy one of these stepper motors?
    Do you know an approximate price of these motors?
    Thank You,
    Roger
    MOONSIndustriesCH's Avatar
    Mar 2018
    Shanghai
    This is the stepper motor made by Taizi, a Chinese brand
    The specification as follows for your reference:
    57BHH56P-560A-29
    Step Accuracy---------------------------------±5%
    Temperature Rise----------------------------80? Max.
    Ambient Temperature Range---------- -20?~+50?
    Insulation Resistance-----------100M? Min.50V DC
    Dielectric Strength-----------------500V AC 1minute
    You could search their products information on Alibaba
    If you need MOONS' stepper motor, please visit our e commerce website wwww.moonsindustries.com
    Mar 2006
    I didn't find this specific Taizi motor on Alibaba?
    Does Moons have a stepper motor which has the same specifications as Taizi 57BHH56P-560A-29 stepper motor?
    What is the price of the Moons stepper motor?
    Does Moons have a distributor in the U.S.?
    Thank You,
    Roger
    Mar 2006
    Does anyone have any information about the stepper motor below?
    Type 23HD450Y-31A6
    I assume the first part of the line above is the manufacture date, 170713.
    Thank You,
    Roger
  7. #7
    I know that this a little old at this point, but if anybody needs the spec sheet on the Nema (Smooth Stepper Motor) 23HD series of stepper motors, they can find it at the Smooth web site at: Long Lasting nema 23 steppers With Long Warranty . If you are looking for a particular Smooth stepper motor, do a google search by replacing Smooth with Nema. I.E., if the motor was a Smooth 16HY001-2, to find it you would google Nema 16HY instead, which will take you right to the Smooth Product Page for 16HY motors with their spec sheet. Hope this helps somebody.
  8. #8
    Member jdcrouch's Avatar
    Nov 2019
    I know this is a post over a year old, but did you by chance ever find the spec on the 23HD450Y Smooth stepper motor. I looked on their website and I found specs for a lot of other motors but haven't been able to find this one.
  9. #9
    Member GPM83's Avatar
    Jan 2020
    Also looking for it.
