Get a Gecko G540. Have been using there drives for years.
Hi
A bit not familiar with that type of replacement.
I have 4 nema motors Keling KL23H276-28-4B and I work with Mach3 software.
My Rockcliff stepper driver card 4X discontinued (PN RCF_00110) needs to be replaced. (see picture attached)
What type of stepper driver card would you suggest me as a replacement, with a good quality-ratio and using the same Mach3 settings already registred on my pc.
Jack
Gecko might be a bit of overkill, but if you have the money, go for it.
James hosts the single best wiki page about motors for CNC hobbyists on the net:
http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
Thank you for your reply,
If you have suggestions for cheaper versions it would be appreciated.
Jack
*cough*
Still overkill for a replacement for that board, but they cost a lot less because they are kits.
Are you not happy with rockcliff? They do make a replacement, with a better chip:
https://www.rockcliffmachine.com/product/drv8825-step-motor-driver/
Very very cheap. If the original worked, the new one can probably manage. But neither of those drivers can get the full performance out of your 3 amp motors. You need a driver than can do 3 amps all day long, so I would really recommend a 4 amp driver.
