Im making a simple setup to move 2 stepper rails on the X and Z with only buttons and no computer.
I have bought cheap components in China. Im not a electronic specialist so i bought a compleet cnc board and i not want to work with computer or arduino or so.
The components i use i attached as photos.
Im almost sure i attached the motor the right way to the motor driver. But im not sure if the wires from the driver are connected good with the control board.
The drivers i powered with a 12v 5a adapter. The board i power up by USB cable.
When i put the power on the system the drivers both will show a red light. The control board is powered up and reacts on pushing the buttons on the remote. And when i power up i hear the motors react. But with pushing the buttons on the remote the motors don't react. What did i do wrong?
I just want it to work with pushing the buttons on the remote! No PC or so needed.
Try this:
XN goes to EN-, DIR- and PUL-. This is the common.
XD goes to DIR+. This is the "Direction" signal.
XS goes to PUL+. This is the "Step" or "Pulse" signal.
XE goes to EN+. This is the "Enable" signal that turns the stepper drive on.
