I'm building my first 3 axis (amateur) CNC. Construction is made of MDF and I'm using TB6560 drivers and Nema 17 step motors. I have wired all TB6560 drivers to the board but 2 axes are working fine and one is not working correctly. Settings are same for all 3 drivers (and motors are same). You can see how it works in video that is uploaded. First in video is X axis, second Z axis and third is Y axis that is problematic. I have visually inspected that driver that is not working normally and it is not phisically damaged. Don't know what is the problem, is it with driver or something else, so I'm asking you if you can help me.
