Wiring of stepper controllers
Results 1 to 4 of 4
Thread: Wiring of stepper controllers
    Member TTalma's Avatar
    Jan 2013
    Default Wiring of stepper controllers
    I just purchased an AXYZ Millennium table. With no front end control. There is a custom board to interface with the PC that I will remove. It uses 2 different stepper drivers a Pacific Scientific 6410 on the Z axis and 2 AXI 2200's for the X and Y.
    I am planning on removing the custom AXYZ board and replaceing it with a Warp 9 Smooth stepper.
    The thing that is confusing me is that the Step+ and Dir+ are tied together on all 3 axis (Step- and Dir- are separate). Is this common? Will it work with the sooth stepper, I can break the signals out separately on the Pacific Scientific driver, But I cannot find any documentation on the AXI driver so I am not sure how to handle those.
    Dec 2005
    Default Re: Wiring of stepper controllers
    that can work that way it's called common anode and it may work common cathode . you can wire your breakout board to connect either way .Do you have a pic of the drive?
    Attached Thumbnails Attached Thumbnails Wiring of stepper controllers-common-anode-cathode-png
    Member john-100's Avatar
    Mar 2007
    uk
    the Pacific Scientific 6410 has all 6 terminals from the step , direction & enable opto-isolators available
    so you can either
    connect the + step , +direction & +enable to +5V and connect the - step , -direction & -enable to the 3 smooth stepper outputs
    or
    connect the - step ,- direction & - enable to 0V/gnd and connect the+ step ,+ direction & + enable to the 3 smooth stepper outputs
    you will just have to set the outputs to either active high or active low accordingly
    while the smooth stepper outputs can sink (to gnd) or source (from +5V) 24mA
    Wiring of stepper controllers-ethernet-smoothstepper-bi-directional-io-jpg
    it would be safer to use a smooth stepper breakout board or C10 breakout board to protect the smooth stepper
    ( I have not used a smooth stepper so I'm not sure how well its outputs are protected from shorts to the 5V power supply )
    John
    Dec 2005
    the ESS documentation states "The ESS relies on the breakout board for isolation " and "The ESS has drivers that are capable of driving opto-isolators directly" thru the 74ACT541 chip as john shows.
