Do strange things happen only to me?
I noticed while I was working on a piece that no object korisponde I was working from the drawing. for example a retet of 200mm and 70mm width and 195mm to 70mm. I have two engines and I decided to check that I did not move to the right size and set it. After that these noises were presented. It seems to be working together with axis to make lateral displacements. I tried to change the micro step, speed, acceleration, gcode the problem remains. I use the 5ax controler and tb6560 v2 3A driver. If anyone has had this bad experience, please help me. Thanks in advance.
The recorded video in which you see and hear the noise
I do not know if it's the right section and I apologize. I just changed the control and nothing changed. I made a video in which the strange noise is seen in the first part and in the second the axes move singularly the noise disappears.
here the link:
Sounds like resonance, and the motors stalling.
What microstep settings are you using?
UCCNC 2017 Screenset
8 micro step.
