Why not contact the people you purchased the units from? Don't they offer technical support? I always support the units I sell...
hey every one
it is a really problem
because i hade one driver is gone .........
so i need the correct connection and all the photos from internet not have that compaination
the driver is ((( http://www.cnczone.com/forums/attach...d=300252&stc=1 )))
the interface board is ((( mach 3 5 axis board )))http://www.cnczone.com/forums/attach...d=300250&stc=1
i hope some one help me
James hosts the single best wiki page about motors for CNC hobbyists on the net:
http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
Hello
I have the same 5-axis board and the same driver.
Could you tell me how you connected?
Thank you very much.
for each stepper driver you can either
connect all of the step + and direction + terminals to the +5V supply to the breakout board
and the step - and direction - to the appropriate BOB outputs for the axis
setting the outputs to active low in mach3
or
connect all of the step - and direction - terminals to the 0V / ground supply to the breakout board
and the step + and direction + to the appropriate BOB outputs for the axis
setting the outputs to active high in mach3
John
