Poorman56,
Remove the wire connected to the enable.
Jeff...
I just got my cnc kit and hooked them all up for a test run and there is one that has a blinking green light. I switched the motors around and still the same thing.
any ideas on whats wrong?
- CNC setup confusion on X2 minimill, DM542A drivers, DB25-1205 BOB, & mach3
- Need Help!- Replacing Syil Stepper Driver With Other driver. No Luck getting motion
- Wich kit should i choose? DM542A or TB6560
- Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
- STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
Poorman56,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
removed the wire and it still blinks
With power supply off remove all wires except power wires then power back on and see if led flashes.
Did you figure out what as wrong? I am having the same poroblem with my DM542A. I dont have the jumper enable and I see that that was the last comment on the feed...?
Know this is resurrecting a dead thread but I am having the same issue with a DM542S, blinking green light. Followed the suggestions above but the issue still persists. There is NO documentation out there for a flashing green LED on these drivers. Any help appreciated.
