Originally Posted by
dariocnc
Thanks for the infos!
I kindly ask you which could be the problem with one of my drivers DM860A:
- after a working period with no problems, now the red light comes on every time it start to move the attached Nema 34 motor,
I have tested the power supplier (350W 60V) and the motor with a similar stepper driver (another DM860A) and they both work, so the red light is not due to PSU and motor attached to the drive.
The red light turns off is I reboot the driver, but as soon as the motor starts movement the red light swichtes on and the motor stops.
Which tests should I do to understand which could be the red light problem? I am not a technician but I have a tester/scope for diy.
thanks in advance
