well First off Thanx Admin for finding my missing post and posting it
the reason to wait for Admin was out of Respect to the Rules of these forums.
I mentioned 74LS14 because that is what is listed on the schematic for the haoyuelectronics Module, that schematic shows no such Diodes, also the Schematic has no Revision Level.
I do not know what components are on the N2 Rev board because I do not have one ... I only have the N6 board.
the last image that you posted looks like the N6 but the area where the PCB numbers are on the upper left corner are not listed on your Image.
The Diode on the left, which I assume you wish to replace with a fuse is to prevent damage if the supply voltage polarity is reversed, the other 4 diodes are "FreeWheeling Diodes" put there as Spike Eaters, I can't say that is a bad Idea.
this was just an update to say Thanx for posting my original Post, I will post again when I have finished tracing out this N6 PCB
EDIT:
the Slow PC817 OC is just for the Enable signal, there is no reason it needs to be a Higher Speed OC, the other 2 OC's for Direction and Pulse are in Fact High speed units.
