Hey John,
Just curcious and also for learning, under what conditions did you drive the board: supply voltage (+amp capability) + what type (unregulated,switching, regulated), rated amps of motor, microstepping?? and how did the board die? more than one axis? what conditions+ what part blew? And also, how long did the board last under working condition? And did you check motorAmps output while driving the board?
Regards
I cannot help in building a PCB that's more in lucas's field of expertise. the flaws you mentioned i think can be worked around and for myself if this chinese p***e of c**p fails i'm buying myself a gecko drive. (or i'd better buy one straight away, but i like a challenge).
