Need Help! Sanyo Denki stepper motot driver failed
Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Sanyo Denki stepper motot driver failed
    Dec 2011
    Morocco
    Default Sanyo Denki stepper motot driver failed
    Hi everybody,
    I bought 3 Sanyo Denki (103H7126-1740) stepper motors to build a CNC but I got some problems with drivers, I tried the L297+L298 stepper driver but the L298 gets hot after a while and burn out, then I tried the L297+ 2XL6230 which turn off once hot, I also tried PIC microcontroller + Mosfets (TIP161&TIP145) but the mosfets burn out after few minutes. I'm trying to make them work fine months ago with no result.
    The motors scpecifications are:
    - Bipolar
    - Current: 4 A
    - Grade: 1.8 ° + / - 0.09 °
    - Holding torque: 165 Ncm
    - Resistance: 0.48 Ohms
    - Inductance: 2.2 mH
    - inertia: 360 Kgm ² x 10 -7
    - Theoretical acceleration: 45,800 rad x sec -2
    - Constant voltage: 31 V / krpm
    - Weight: 1 Kg
    Help me pleaaaaaaaaaaaase :'(, thank you verry much.
    Jan 2005
    Belgium
    The DIY open source THB6064 is a perfect candidate for a 4Amp and 2.2mH motor.
    http://users.skynet.be/ldt/CNC%20ele...THB6064AH.html
    or
    THB6064 MassMind Stepper Motor Driver Kit
    Dec 2011
    Morocco
    Thank you so much Lucas for your reply but I didn't find the THB6064AH chip in the store.
    Jan 2005
    Belgium
    Almost everybody uses full partkits, some only a PCB and chip.
    I can supply the chip only, please send a PM if you need some.
    Dec 2011
    Morocco
    Please guys any suggestions, please help meeeeee :'(.
    Gold Member
    Jan 2005
    Toronto, Canada
    What is your objective?
  7. #7
    Dec 2011
    Morocco
    Quote Originally Posted by H500 View Post
    Hi, I need to drive those steppers, I need them to work good
  8. #8
    Banned yours_prabhat's Avatar
    Dec 2008
    India
    Gold Member
    Jan 2005
    Toronto, Canada
    Quote Originally Posted by scalance View Post
    The link does not show a motor.
  10. #10
    Jan 2005
    Belgium
    @H500:
    That link is automatically created by CNCzone to one of their sponsers for additional income, it's not a link to his steppers, the spec's are in the first post. I have been confused by this for a while also, you can turn most of these auto-created-links off in the user control panel.
    @scalance:
    Your first post showed that you are a DIY guy, that's why I linked to a DIY solution wich is a good drive for these motors.
    There are other drives: Gecko G540, Leadshine... but these aren't cheap.
  11. #11
    Dec 2011
    Morocco
    Quote Originally Posted by lucas View Post
    @H500:
    @scalance:
    Thanks Lucas, but as you said those drivers aren't cheap and I like to make myself things so I undertand how they work exactly
  12. #12
    Dec 2011
    Morocco
    Quote Originally Posted by yours_prabhat View Post
    I looked for the THB6064AH but didn't find them in the store
