Reading over the TB6560 datasheet again, I noticed something else:
When you look at the actual power dissipation, (page 6 on the data sheet)
http://www.toshiba-components.com/mo...3_20080407.pdf
it handles LESS than 43 watts (43 watts with an infinitely good heat-sink, which doesn't exist) which is only a bit over 1 amp at the max 40 volts. Even with a 24 volt supply, it will fry above 43/24=1.8 amps. Only using 19 volt power brick? It will fry at 43/19=2.25 amps. Actually, it will fry before that, even with a really good heat sink.
