V4 coming up
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: V4 coming up
    Registered balsaman's Avatar
    Mar 2003
    Default V4 coming up
    I wish it wouldn't crash.
    Registered mark c's Avatar
    Sep 2004
    US of A
    Cool!!!
    Keep us posted!
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Mar 2003
    Heads
    Attached Thumbnails Attached Thumbnails V4 coming up-engine4002-jpg
    Mar 2003
    Oct 2005
    Looking very nice Mr Balsaman!
    Keep the pic's coming please.
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    yeah! I'm watching too! keep us posted on your work.
    John(bloy)
  7. #7
    Feb 2004
    hh
    looking good Eric
    should have lots of power
  8. #8
    Banned
    May 2006
    England
    any more progress on this one balsaman? looks interesting!
  9. #9
    Mar 2003
    Final assembly is tonight. Stay tuned....
  10. #10
    Mar 2003
    It runs. Video soon...
  11. #11
    Mar 2003
  12. #12
    Sep 2004
    US of A
    Balsaman, That is way cool!!!
    One question. How did you handle the distribution & timing of the pressure? Can't figure it out from the pics
    Mark
    www.mcoates.com
  13. #13
    Apr 2003
    Ohio, USA
    That was a fun video Eric, I loved it
  14. #14
    Banned
    May 2006
    England
    Very nice balsaman. Very neat. It would probably run more smoothly with a flywheel although it's pretty smooth anyway.
    Runs quite slowly, it it a long stroke? is that why it's called the lazy v4?!
    Yeah what sort of valve gear is it balsaman? From the first pic it looks like there are two holes for piston type valves in the block. How are they driven and are the exhaust ports on the outer sides of the block??
    Thanks, great engine ..
    Nick
  15. #15
    Mar 2003
    Yes there are 4 piston type valves driven off of ecentrics on the main shaft. Two valves on each ecentric. The exhaust is directed out the top of the cylinder into pockets over the valves in the head and the pockets are ported to the outside via a hole in the head. Here is a 3D view to look at that could clear things up a little...
    Bore and stroke .75" x 1.5"
    The thing will run quite slowly altho it will do what seems like 5000 rpm if I crank up the pressure...
    Flywheels are coming up soon, hang on...
    Eric
    [hr]
    [hr]
  16. #16
    Banned
    May 2006
    England
    Excellent Balsaman. You designed the engine yourself didn't you? Very unusual and unique. At least here in the UK we don't see much like that.
  17. #17
    Mar 2003
    Thanks. Yes, it's my own design and first design.
    Eric
  18. #18
    Registered drawbar's Avatar
    Apr 2004
    Way cool.
    Does it self-start or do you have to give it a little 'kick'?
    Brian
  19. #19
    Banned
    May 2006
    England
    Impressive! Great little engine, I bet other people would be interested in building that.
    Was it difficult to make?
    So what's the next project then??
    I noticed you'd done a Webster gas engine, how was that to make? I've never made an i.c. engine yet.
    Thanks,
    NIck
  20. #20
    Mar 2003
    Quote Originally Posted by drawbar
    Way cool.
    Brian
    It self starts, altho I need to up the pressure a little sometimes to get her to go, then I can reduce it to keep it running. I might try and play with the timing a bit to optimize it.
    I am building a stand and some flywheels. Stay tuned.
V4 coming up
V4 coming up
