100 psi will be 338 degrees F. 150 psi will be 366 degrees F. I'm pretty sure at 100 psi you'll need about 6.64 GPH and at 150 psi you'll need 9.41GPH. I would suggest a closed loop steam system that way you won't need a lot of water and it will take less energy to keep it heated.
