Spindle Control with PWM PSU
Results 1 to 2 of 2
Thread: Spindle Control with PWM PSU
    Member federicken's Avatar
    Apr 2023
    Default Spindle Control with PWM PSU
    Hello Everyone this is my first post.
    I have received from Aliexpress my 800w Spindle with the respective PSU PWM controller with 4.7 k pot (https://www.aliexpress.com/item/1005001551850219.html the one i have is similar to this). Spindle is DC 110V rated. I want to control this with MACH3 breakout red card.
    I cant find any trustable info on how to wire the card to the controller with the purpose of controlling the spindle with MACH3 Breakout card (bit sensor one; aka red pcb);
    Additionally: What does the pin exciter does?
    Thanks in advance.
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Spindle Control with PWM PSU
    The short answer is no, you cannot control this PSU with a breakout card. It is cheap for a reason.
    The "exciter" output goes to the excitation winding (for special motors where that winding has its own leads).
