I'm trying to set up my spindle speed with mach3 software with pokeys57CNC interface board.
I have a multiplier of 0.00416, 24000 rpm spindle, kernel speed 20 khz, PWM base 2000, but my spindle runs 4 times as fast as what i put in mach.
The ratio of the pulleys is 1.
The number of poles is set to 2
The rotating speed/ motor revolutions is set to 3000
Im trying to get the good RPM ratio by changing the pulley ratio but nothing happens.
Any help would be much appreciated
- Any suggestions for replacement 2.2kw 24000 RPM spindle? Who is a reliable seller?
- 2.2kW Chinese Spindle with vector-control-VFD (Huanyang GT series 2.2kW drive)
- Need Help!- Hitachi Wj200 and 2.2kw spindle unsteady RPM
- Is it possible to install a RPM sensor inside a 2.2kw Water Cooled Spindle
- CHinese 2.2kw spindle low rpm
