Help with a H100 VFD for a Spindle
Results 1 to 2 of 2
Thread: Help with a H100 VFD for a Spindle
    Izula369's Avatar
    Feb 2023
    Default Help with a H100 VFD for a Spindle
    Hey guys,
    I wanted to see if anyone might be familiar with the H100 inverter.
    I am using a PWM to Voltage converter and I can change the Hz by changing the PWM output, but I cant get it to actually run.
    I am not sure if I am missing something in the config or the wiring.
    Right now from the PWM converter I have a wire running to the Ai1 and ground port.
    Attached Thumbnails Attached Thumbnails Help with a H100 VFD for a Spindle-img_6986-jpg   Help with a H100 VFD for a Spindle-img_6984-jpg   Help with a H100 VFD for a Spindle-img_6988-jpg
    Member mactec54's Avatar
    Jan 2005
    Default Re: Help with a H100 VFD for a Spindle
    Quote Originally Posted by Izula369 View Post
    Hey guys,
    The PWM to Analog Converter does it output 0-10v and Changes with the S12000 =5v this connection is only for the speed control; you need a controlled Relay also for the 0n /0ff control
    For 0n / 0ff you need X1 / GND connected to a Relay (no Voltage switch) that is controlled by a configured output
    Mactec54
