Originally Posted by
mactec54
The PWM 0-10v Analogue output from Mach3 is under 5v if you can only run at that speed, which you can measure to see what the output voltage is, you can't adjust the speed because it has not been setup correctly or is not working.
As I said your Parameters and or wiring is incorrect, if that can happen is not safe to use, if the VFD restarts after you press the Stop button then you have a wiring problem or Parameter setting problem, it means FWD and COM Terminals, are staying active and not disconnecting when you hit the Stop Button, this is very dangerous, to use like this as the spindle could start when you are changing a Cutter.
To disengage the Mach3 Remote connection you can just change 2 or 3 Parameters and you will have full KeyPad control, to do a real test, by the Parameters you listed the main speed Parameters are correct. whether you have the rest in place that is needed is up to you to find what other Parameters have been set.
Motor Parameters are important, you listed the b0.04=400 as being set so may be these others motor Parameters are set also??
b0.01=2.2Kw
b0.002=220
b0.03=9
b0.04=400
b0.05=14000
F0.02=0 (0r (3) For Pot Control)
F0.04=0 (0) For KeyPad control (1) for Remote Control)
F0.09=0 (0) For KeyPad Control (4) For Remote Control)
You are lucky that this VFD Drive is Robust and can take some punishment, but when it decides it's enough, it will fail if you don't correct its requirements.
If you change any Parameters Take Note of what the # is so you can go back if it does not work incorrectly.
