Setting up a Lenze VFD with new C11G controller for CNC Router
Results 1 to 2 of 2
Thread: Setting up a Lenze VFD with new C11G controller for CNC Router
    TempestDon's Avatar
    Nov 2022
    Default Setting up a Lenze VFD with new C11G controller for CNC Router
    I am upgrading my CNC to closed loop motors, which required me to get a new controller. I am trying to figure out how to set up the current Lenze VFD with my new C11G controller. Things aren't labeled the same, and I am inexperienced enough to now know how to translate between them.
    The C11G wiring diagram and the description of the Lenze VFD terminals are both attached. I'm thinking it would be set up like this, (but nothing is working yet in Mach 3, so I don't have something quite right):
    VFD 11 would provide 12vDC to 12vdc input
    VDF 5 would go to 0-10V input
    VFD 2 would go to ACM
    VFD 1 would go to Forward
    VFD 4 would go to DCM
    I don't use reverse, so I don't think I need anything?
    If you have any different opinions or advice, I would sure love to hear them.
    Thanks,
    Don
    Member mactec54's Avatar
    Jan 2005
    Default Re: Setting up a Lenze VFD with new C11G controller for CNC Router
    Quote Originally Posted by TempestDon View Post
    Thanks,
    Don
    Nothing attached. no nothing required for reverse
    Mactec54
