Help Mach 3 Spindle Relay Alternative / Work around
Results 1 to 2 of 2
Thread: Help Mach 3 Spindle Relay Alternative / Work around
    Member Snazzy's Avatar
    Nov 2020
    Post Help Mach 3 Spindle Relay Alternative / Work around
    Help please, I’m trying to figure out how to turn 2.2kw spindle on with mach 3 with the mach 3 5axis break out board. Only problem is I have 5 stepper motors attached. With pins 2-9, 16/17 being used already, I don’t know how to turn spindle on without removing a stepper motor. Any ideas how to get the spindle relay to work to control spindle on/off?
    I have pretty much wired and set up mach 3 properly I believe. I just have to many stepper motors for this break out board? If I disable my stepper motor, B Axis, Pin 16-17. I can have spindle relay set up with Pin 17 and I can turn spindle on but I cant use that stepper motor.
    Only thing I can come up with is maybe using one of 2 pins I have left (14 or 1) and setting up spindle relay through that but its only 5V power as opposed to 10V. Not sure if that would even work. Or if I can avoid not need spindle relay at all.
    Attached breakout board and VFD manual I have. Spindle is 2.2k 220v 10amp.
    Any help would be appreciated.
    Thanks, Aaron.
    Attached Files Attached Files
    Member mactec54's Avatar
    Jan 2005
    Default Re: Help Mach 3 Spindle Relay Alternative / Work around
    Quote Originally Posted by Snazzy View Post
    Thanks, Aaron.
    The relay is just a switch and requires no power if connected correctly to turn the VFD Drive 0n /0ff so the 5v at you Board just turns 0n /0ff the Relay the output of the Relay will have no voltage this connects to the VFD FWD / XGND
    For speed control you will need the 0-10v Analog output connection too VII /GND
    So use relay on your Breakout Board that is used for the Spindle 0n / 0ff connection for your axis problem you can use an Axis splitter 2:1 you can get one or whatever you need from CNC4PC it is a part number C88
    Attached Thumbnails Attached Thumbnails Help Mach 3 Spindle Relay Alternative / Work around-2-1-axis-board-c88-png
    Mactec54
