Originally Posted by
00chris
Hello guys,
I am new to the group and I am facing an issue with my new huanyang VFD
The spindle is: 400Hz, 24000 rpm, 1.5Kw, 8A, 110V. 3phases 2 poles
VFD MODEL: HY01D511B, 110V-110V, 1.5KW, 13A
The first time I tried to run the spindle, the spindle turned for like 15 minutes and then stops, VDF shows E.o.L.A error
I tried these settings before:
PD001 = 1
PD002 = 1
PD003 = 400 = Main frequency
PD004 = 400 = Base frequency
PD005 = 400 = Max operating frequency
PD006 = 3.0 = Intermediate frequency
PD008 = 110 = Max voltage
PD009 = 7.5 = Intermediate voltage
PD010 = 4 = Min voltage
PD011 = 120 = Frequency lower limit
PD070 = 1 = Analog input
PD072 = 400 = Higher analog frequency
PD141 = 110 = Rated motor voltage
PD142 = 7 = Rated motor current [motor says 8A] – Setting won’t go any higher than 7
PD143 = 2 = Number of motor poles
PD144 = 3000
After these parameters, I got others which are a bit similar to the first ones but I now get the E.o.L.d error
PD001 = 1
PD002 = 1
PD003 = 400
PD004 = 400
PD005 = 400
PD006 = 3.0
PD007 = 20
PD008 = 110
PD009 = 7.5
PD010 = 4
PD011 = 120
PD014 = 10
PD015 = 10
PD070 = 1
PD072 = 400
PD073 = 120
PD120 = 100
PD141 = 110
PD142 = 7
PD143 = 2
PD144 = 3000
Can anyone help me to ensure I have the right parameters set.
Thank you.
