The first thing you have to look at do you have the power to run it a 2.2Kw will need a a minimum of a 25A mains power supply for it to run correct, you may find that your 1.5Kw has a power supply problem how is it wired, how many amps is the circuit it is on, and what VFD Drive parameters have you set
You should not use YouTube as most setups are incorrect, they can be a helpful as a guide only, most don't know any more than you do, that make these videos
Vevor is not as good as what you have, it's a new player in the market that does not make anything, they just rename rebranding of other Drives and Spindles Etc.
