- Need Help!- Specs for Sanyo Denki BL Super 64BM180KXS79
Dear Forum Members
I have a Sanyo Denki BL Super 64BM180KXS79 Spindle Motor ,10K rpm, in a Brother CNC TC324 Tapping Machine.
I can not find any solid information in the Internet regarding electrical specs for this motor.... What I am looking for is :
# of Motor Poles,
Motor rated Frequency
Motor Maximum Frequency
Motor Rated Current
Motor Rated Torque
Spindle Amplifier is Sanyo 67ZA150MXXXC01 and is feed by 200 VAC.... I assume that will be the Rated Motor Voltage.
I need this info since I decided to convert machine from Conversational control to NC control, using a SZGH 1500MDb control and SZGH AC Servo Motors, Amps and Spindle Amp only.... their spindle motors are too big in flange size.
Therefore, I have to use the OEM Spindle Motor with their Spindle amp.
Can someone help me with this info?
Thanks in advance for your help.
- You may not post replies
- You may not edit your posts
Forum Rules
