I set p080=4 now the vfd runs on startup and I can't stop or reset
And YES IKNOW I F ed up. Anyone now how to shut down/stop
- H100-2.2C2-1B VFD to C11G Board
- Huajiang VFD H100 and 1.5KW Spindle Speed Control
- Need Help!- PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
- New Machine Build- Implementing VFD control on the G540 - into a non-VFD variable-Vin PWM controller
- doosan ACE-H100 pallet APC arm return fault
Ok, I have the Manual so check to see if F000. =0 if (1) the Parameters are locked you can disconnect the spindle while trying to get it working again
Just set P080=0 back to (0) for normal operation, if you can't Reset this Parameter, you will have to do a Factory Reset, and reprogram the Drive to suit your spindle specs
Mactec54
