Here is the link of my problem. I set it 10000rpm but rpm doesn't remain constant it increase and decrease by itself
Hi.
I am having problem of spindle speed fluctuation. My rpm goes +-500 to +-800 up and down always amd doesn't remain constant
My machine have 1.5kw 400hz water cool spindle with ae-200 vfd.
Need help as this problem effect my aluminum milling jobs.
One thing more. It doesn't fluctuates when rpm set to 24000
Also i check. My spindle is ground correctly my machine is ground correctly and my vfd main 220v is ground correctly
- Need Help!- Mori seiki MV 40 Spindle Drive speed does not match S-code speed
- Need Help!- high speed and low speed dual spindle CNC mill
- Spindle speed issue PRT-E750. Spontaneously speed floating.
- Help chosing a spindle speed sensor to indicate spindle speed in mach3
- BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
Mactec54
