It does not mention anything about RS485 in the video, so not sure how the control is working with RS485 connection, as that would also need to be setup, if you have set Mach3 the same as the video, then you should contact your control supplier
Some Parameters are questionable for this spindle, what are your motor specs, they also should not be reversed so that part should not be set
Is, your spindle air cooled??
