It depends what motor you are running as to what those Parameters are set at the Default in the VFD Drives are either for a 50Hz or 60hz motor the Parameters you found are most likely what I have posted and are for 400Hz high speed spindle motors
So, depending on the motor you are using will depend on the VFD Drive Parameters to be set.
