I have the above VFD but no manual. Does anyone have a link to the appropriate manual? I hate to buy a new VFD just to get the correct manual. Here is a link to the VFD on Ebay
Jim
- Need Help!- VFD Configuration With Huanyang VFD [ Model: HY02D223B ], C10, C6, Mach3
- Need Help!- PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
- Repair VFD 1.5kw Huanyang (Never connect to 3 phases if is 1 phase VFD)
- Hwo need the wiring about the dsp 0501 board with the vfd and parameter of the vfd :)
- New Machine Build- Implementing VFD control on the G540 - into a non-VFD variable-Vin PWM controller
VFD A2 8075 por favor alguien que tenga la configuracion en espanol para conectar dos controles con su respectivo motor cada uno y que pueda desconectar los dos motores con un contactor doble y no se bloquee los VFD
