No matter what speed I put into mach3 it gives me BWM bumped to minimum setting. The manual said if you are using mach3 then don't turn power on for VFD.
Now I had tried it before with the VFD power on and spindle starts going and gets an err13 appears when it gets to about 70 on the display.
I am only in the setup stage. This is brand new never used before so I wouldn't think the spindle motor is burnt out.
