It's not really pressurized, it is free flowing to keep the dust and chips out of the spindle bearings, this is very common for any type of CNC machine to have, quite often the air flow is also carrying a lube as well to lube the spindle Bearings, if it is a woodworking spindle then it would only have the air flow, this has to be dry air as well or the Bearings can be damaged if you have water in the compressed air
