looks like your vfd has 2 or 3 modes you can use V/f, vector control(FOC) and sensorless flux control(SFVC). I don't know how exactly you change from one to another but maybe therein lies the problem.
Has anybody out there had any success using the soyanpower svd-ps vfd for their spindle control? I’ve been struggling with getting mine programmed to work with Mach4 and would like to see if I’m overthinking it, or if it really needs as many parameters set as I’m thinking it does? Since it’s a Chinese vfd, there is a little bit of chinglish going on in the manual, although they did pretty good on it, but I can’t figure out if the “pulse settings” is the same as setting it up to be commanded by pwm, which is what the controller is using or if it is meaning something different. Things of that nature. Is there a generic, run of the mill, set of parameters that need to be set in order for it to work? I understand every vfd and system is different, and will have different parameters and what not, but I’m sure for the most part, a lot of them have to have pretty similar changes in order to to be programmed to work with a cnc
- Need Help!- HY02D223B VFD with 2.2KW Watercooled Spindle GDZ-80-2.2A Spindle - External Controls
- Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
- Need Help!- HELP ES100 VFD and 2.2KW spindle - SPINDLE RUNNING HOT/VFD ERROR!!!
- Need Help!- Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
- 2.2 kW spindle with Hitachi VFD or 3 kW spindle with Huanyang VFD
Do you have a link to the VFD Drive or a PDF you can post
Not may VFD Drives will take direct PWM for the speed control so need the PDF and I will tell you what you need to do
No, there are not normally very many Parameters to set so if you have played with lots then this could be a problem
Mactec54
Sure, I’ll tag the link down at the bottom. And I’d REALLY appreciate any direction I can get. Everything up until this point has been a cakewalk except the vfd. I’ve never had to program one for a cnc before and I’ve messaged the manufacturer several times and never got a reply. Since you’ll probably need this info as well, I’m using a pmdx 424 b.o.b. with pmdx 407 spindle controller, running Mach 4. Thanks again
https://www.ivdc.com/cnc/SVD-P%20user%20manual-NEW.pdf
After reading the description of each setting, I believe sfvc is still the best option since I don’t have a spindle encoder (yet) for clvc, and apparently v/f is for low load or multiple motor applications. Though I will be picking up a spindle encoder sooner rather than later so I’ll switch over to clvc
Mactec54
