Hello all, I just purchased a used 4x8 CNC router, It is equipped with Richauto A11 DSP, spindle is a 5.5kw,380v, 400Hz, VFD needed to be replaced, replacement VFD is a 11kw, 220 1ph to 380 3ph, model # DFL5800, tried to load the manual but is to big to upload, Can someone please help on how to set up the VFD with Richauto A11 all motor parameters are set on the VFD. Thanks a lot in advance.. Have the link for the manual but I'm not sure if I can post it here....
