Originally Posted by
mwaldorf
HOLY QUACAMOLE - IT'S ALIVE!!!!
I replaced the cable from the VFD to the spindle, and no more tripping breakers! What confuses me is that I tested the previous cable over and over with a multimeter and found no shorts. Maybe the old cable was playing games with me?
So, that leaves the following:
1. Spindle cable shielding is not connected yet. I was thinking about attaching it at the VFD ground, along with the power cord ground and the fourth pin of the cable which is connected to the spindle chassis (pending answer to #3)
2. VFD max frequency - VFD max frequency appears to be 266Hz. Not sure why, but probably enough rpm for my needs.
3. VFD mounting - Do I need to mount the VFD to a metal plate, and if so, how is the mounting plate connected to ground?
Mactec, CNCMan, JoeAverage: thank you so much for your help!
