Need Help:
Results 1 to 3 of 3
Thread: Need Help:
    Member msimard44's Avatar
    Jan 2022
    Default Need Help:
    We have a 10HP (7.5kW) Vevor spindle motor that needs 380VAC. I'm looking for either:
    1. VFD that can take 460/60/3p input and provide the 380V to the spindle motor
    2. transformer for 460V to 380V
    Any other suggested solutions?
    Any suggestions on where to source VFD or transformer? I can't seem to find anything.
    Thanks!
    Mike
    Nov 2013
    Default Re: Need Help:
    VFDs vary both the frequency AND the voltage to the motor.
    Any 400V (nominal) VFD will work for you. You can program the max voltage and max current.
    Craig
    Jan 2022
    Craig,
    Thanks for the reply. I'll definitely check that out!
Need Help:
Need Help:
