Spindle motor wiring diagram
Results 1 to 3 of 3
Thread: Spindle motor wiring diagram
    Jan 2012
    Default Spindle motor wiring diagram
    I have a spindle motor with the following motor tag. I'll be using the rating in the box - 230v @ 50 hz.
    Spindle motor wiring diagram-motor-tag-jpg
    The diagram from the cover showing how to jump the leads; seems simple enough.
    Spindle motor wiring diagram-cover-tag-jpg
    Here's where I'm confused. Both the motor on the machine and the spare that came with it are wired like this.
    Spindle motor wiring diagram-20211109_090135-jpg
    Obviously it's easy enough to change the jumpers around but neither motor is wired to match either of those two diagrams. If they were wired for high voltage the power should be coming in on the UVW-1 side and the UVW-2 should have the jumpers but as they are, it's reversed. Both motors had those covers and they were both the same. Should I shrug it off, wire it up the way I need it and move on with life or does this hint at a concern I should have?
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    Default Re: Spindle motor wiring diagram
    on the label of your motor 230VAC is for delta (triangle) connection. Means, you need to connect jumpers "three in parallel" way, as drawn in framed picture.
    The motor connection on the last bottom illustration is "star", ( opposite to "delta" ). "Star" connection used by default everywhere because windings are connected in series in regards to applied voltage - less chances of overcurrent.
    Dec 2003
    Quote Originally Posted by ecdez View Post
    IOW, The method of using either the U2 V2 W2 or U1 V1 W1 for the straps will be identical electrically.
