You may have to do a Factory Reset if you have changed any other Parameters, as this is the only Parameters you need to get running.
Huanyang Mactec54
2.2Kw 110v 400Hz Water Cooled / Air Cooled
PD000=0 ( 1 For Parameter Lock )
PD001=0 (1 For Remote Control)
PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
PD003=400
PD004=400
PD005=400
PD006=5
PD007=20
PD008=110 (Motor Rated Voltage )
PD009=15
PD010=15
PD011=120 ( 100 Minimum Setting For Water Cooled Spindle )
PD013= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
PD014 Acceleration=8 ( Adjust to suit)
PD015 Deceleration=8 (Adjust to suit)
PD023=0 ( Forward Run Only )
PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
PD120=100 ( Stall Prevention )
PD141=110 ( Motor Rated Voltage )
PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM) 3,000= (24,000)
PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
PD072=400
PD073=120 ( 100 Minimum Setting Water Cooled Spindles )
PD174=11 ( To Be Set to the VFD Drives Max Rated Output Amps )
