120v and 2.2Kw is a bad combination to start with, yes it will most likely be a programing problem, but if you have the VFD Drive connected to a 120v outlet then it will not be able to get enough Power / Current to run this 2.2Kw spindle motor
So need to know what Parameters you have set, and how you are powering it with your 120v supply.
