Manual VFD speed control issue
Results 1 to 5 of 5
Thread: Manual VFD speed control issue
    Dec 2004
    Default Manual VFD speed control issue
    Hi I have a Huanyang VFD 110V air cooled 1.5KW spindle with a 400hz and 24000 rpm. Out of the box it seems that all of the appropriate settings are preset correctly. I wired it up and it came on and spun up to 24000 rpms per the display without issue. I built a manual spindle controller and have it wired per attached drawing. I have the VFD setting changes listed as well. My issue is it powered on and the controller worked, but I am maxing out at about 11500 rpms, no where close to 24000 rpms. Is there a setting that I am overlooking that is effecting the rpm output??
    Attached Files Attached Files
    Member mactec54's Avatar
    Jan 2005
    Default Re: Manual VFD speed control issue
    Quote Originally Posted by woodworker2 View Post
    There is no way this VFD was programed as shipped, so you should go through all the needed Parameters that match this spindle specs or at least check them, you are using remote control so all the Parameters related to that have to be set
    Plus the J1 jumper will need to be in the right position
    PD001=1
    PD002=1 ( Plus J1 Jumper Position )
    PD072=400
    PD073=120
    Mactec54
    Dec 2004
    PD001=1
    PD072=400
    PD073=120
    Yes the jumper was moved.
    Dec 2004
    pd072 was set to 400, I set pd073 to 120, now Ican't get it back to display the rpms.
    Jan 2005
    You just have to press the button on the keypad to light up that mode the led will be red for the mode you select
    Mactec54
