spindle speed fluctuations and not max speed - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: spindle speed fluctuations and not max speed
  1. #21
    Member hociSK's Avatar
    Sep 2021
    Default Re: spindle speed fluctuations and not max speed
    good evening mactec54. Today I tried to measure what you advised me, but I have no tension anywhere. Which cable exactly should I measure? I measured 10v and ground. voltage but only max 1.2 volts :/
  2. #22
    Jan 2005
    Quote Originally Posted by hociSK View Post
    You should only be measuring the output from the Breakout Board, not any cables, if 1.5v then you have a problem with the setup in the control or your Breakout Board is bad, these Breakout Boards have not been very good and most have this same problem with the spindle speed output voltage
    Have you connected the 12/24v to the Breakout Board , 12v is normally best
    Mactec54
